Betelgeuse bliver svagere
Indlæg af Lindhard » 08 dec 2019, 19:20
Fra det store udland:
Betelgeuse is a red supergiant core-collapse Type-II supernova (SN II) progenitors.
Photometry from this season shows the star has been declining in brightness since October 2019, now reaching a modern all-time low of V = +1.12 mag on 2019 December 07 UT.
Betelgeuse undergoes complicated quasi-periodic brightness variations with a dominant period of ~420 +/-15 days. Also Betelgeuse has longer-term (5 - 6 years) and shorter term (100 - 180 days) smaller brightness changes.
Currently this is the faintest the star has been during 25+ years of continuous monitoring and 50 years of photoelectric V-band observations. The light variations are complicated and arise from pulsations as well from the waxing and waning of large super-granules on the star's convective surface.
Measures of Wing TiO-band (705 nm) and near-IR colours indicate that currently Betelgeuse has relatively strong TiO-bands and has a corresponding lower photospheric temperature of T~3580 K (relative to T~ 3660 K near maximum brightness- typically V ~ 0.2-0.3 mag).
This is an opportune time to secure photometry, spectroscopy, spectropolarimetry and if possible interferometry and Adaptive Optics(AO) imaging.
Tom A
Tilmeldt: 19 dec 2017, 09:56
Re: Betelgeuse bliver svagere
Indlæg af Tom A » 09 dec 2019, 13:08
Efter at have set din besked i aftes, stak jeg hovedet ud af havedøren og kunne se Orion på vej op i øst.
Betelgeuse var tydeligt svagere end Aldebaran og Rigel og kun lidt klarere end Bellatrix. Det så lidt underligt ud!
Ud fra Rigel og Bellatrix bedømte jeg Betelgeuse til mag. 1,1.
Indlæg af Rudi » 09 dec 2019, 14:10
Lidt vildt, hvis den er faldet næsten en hel magnitude.
Indlæg af Lindhard » 09 dec 2019, 19:34
Det er nok fordi Betelgeuse har forbrændt alle grundstofferne og er nået til jern.
Det kan den ikke brænde af, derfor falder den sammen og mister lysstyrke, og så en af dagene sker dette :o
Indlæg af Rudi » 09 dec 2019, 20:27
Jo jo, det bliver et festligt syn.
Og så skal man lige huske på, at “en af dagene” i astronomisk sammenhæng kan betyde i overmorgen eller og et par tusinde år 😉
Indlæg af Lindhard » 09 dec 2019, 20:37
09 dec 2019, 20:27
Jeg forventer, at det sker omkring den 24. december, det er jo set før ;) ...
Indlæg af Rudi » 09 dec 2019, 20:45
Jeg har lige stået og kikket op i Orion med det blotte øje.
Syntes også, at Betelgeuse virker svagere end normalt, men den er stadig tydelig rød/orange.
Der er desværre masser af skyer, ville ellers godt prøve at lave nogle V-Johnson målinger.
Indlæg af Jens_Jacobsen » 09 dec 2019, 21:11
Har lige sammenlignet med Aldebaran. Den er noget svagere, et sted mellem 0,4 og 0,6 mag sådan ca.. Svært at være mere præcis p.g.a månen.
@Rudi. Det giver ikke meget at måle med CCD/CMOS, da den er så klar. Der er heller ikke nogen sammeligningsstjerner. Visuelt er nok bedst til de klareste stjerner.
Indlæg af Rudi » 09 dec 2019, 21:27
Jeg tænkte at blænde enormt meget ned, det lille dæksel i teleskopdækslet, måske med en papplade med et endnu mindre hul? Men ja, svært at få en sammenlignings stjerne med.
Indlæg af Rudi » 10 dec 2019, 07:23
Der er lidt spændende læsning om Betelgeuse her hos AAVSO.
https://www.aavso.org/vsots_alphaori
Tom A
Indlæg af Tom A » 07 jan 2020, 12:49
AAVSO har i går d. 6/1 udsendt en Alert om Betelgeuse - Alert No 690.
De beder om flere målinger i alle bånd, flere visuelle observationer og spektorskopi. Så her er en mulighed for at bidrage til vores viden om røde kæmpestjerner.
Vedrørende visuelle observationer, så kan jeg kun opfordre til at I prøver det!
Jeg er selv novice i estimering af variable stjerner og selv om at Betelgeuse er klar og sammenligning stjernerne er spredte, så er det altså ikke så svært! En estimering tager højeste et par minutter, så der er masser af tid til at lave andre observationer og billeder i løbet af natten.
Så kast jer ud i det og hjælp AAVSO. :-)
Indlæg af Lindhard » 07 jan 2020, 17:59
Tom A skrev:
07 jan 2020, 12:49
Her er AAVSOs søgekort med bemærkninger
Skærmbillede 2020-01-07 kl. 17.56.18.png (217.95 KiB) Vist 195 gange
Skærmbillede 2020-01-07 kl. 17.57.01.png (111.77 KiB) Vist 195 gange
