Bahtinov maske - positionering
Indlæg af Rudi » 29 okt 2019, 08:17
Går det an, at lægge Bahtinov masken helt ude på enden af dughætten? Og gør det noget, at den ikke er 100% centreret?
Jeg fokuserede sådan her hele aftenen i går - tilsyneladende er det godt nok.
Thommy
Tilmeldt: 25 maj 2018, 14:07
Re: Bahtinov maske - positionering
Indlæg af Thommy » 29 okt 2019, 08:40
Jeg ville umiddelbart sige, at centrering er vigtig. Kan du ikke sætte tre-fire flapper på masken, så den centrerer selvom den sidder på dughætte? Afstanden til masken er til gengæld ikke så vigtig - den kan sagtens sidde udenpå dughætten.
/Thommy
Indlæg af Rudi » 29 okt 2019, 09:05
Jeg Googlede mig frem til denne artikel:
http://www.spike-a.com/bahtinovtips.pdf
Her står der bl.a.:
Basic Tips
There are a few items of confusion on
usage of the mask that I would like to clear up.
First, it is not necessary to center the mask on
the end of the scope.
I’ve heard from some customers who were very concerned about exact
centering of the mask on their equipment. I
tested our Bahtinov masks with my 10-inch
Dobsonian and found that they could be several inches off center, and the location of the
central spike still did not change. This is because it’s the angle of the slats in the mask
which generate the spike pattern. As long as
some of each of the three sets of differently angled slats in the mask are included in the optical path, the pattern will be clear.
Second, the mask works equally well on
the end of a dew shield as it does when positioned directly on the end of the telescope.
This
allows users of Hyperstar systems to use a standard mask placed on the dew shield beyond the
extension of the Hyperstar lens assembly rather
than needing a custom mask to be built with a
central cutout for the Hyperstar unit.
Indlæg af Viggo T » 29 okt 2019, 09:58
Nyttig viden-tak. :D
Indlæg af Rudi » 29 okt 2019, 16:52
Ja, jeg ved ikke om det er rigtigt. Men jeg vil teste det i aften - det er jo en rimelig simpel øvelse.
Indlæg af Rudi » 29 okt 2019, 20:39
Jeg testede og det betyder ikke rigtig noget. Det eneste jeg bemærkede, var at difraktions spikes var skarpere/tyndere, når masken lå korrekt direkte på tubus. De var lidt tykkere når masken lå ude på dughætten, ca 20-30 mm offsat fra centrum. Men i begge tilfælde, viste bahtinov grabber samme resultat; fokus var lige i skabet.
