NEQ6 bælter - hvilke
Re: NEQ6 bælter - hvilke
Indlæg af John » 30 mar 2018, 23:34
Det ser godt ud [mention]rudi[/mention]. Hvor lange exponeringer kører du med i den graf du har vist. Hvilket tal kom guideassistenten frem til i forhold til dec-backlash?
Indlæg af Rudi » 30 mar 2018, 23:36
2 sekunder. Guidecam er et ZWO120MC på et 50mm F200 teleskop. Kan ikke huske backlash tiden. Checker logfilen i morgen.
Indlæg af Rudi » 31 mar 2018, 10:09
[mention]John[/mention]: her er detaljerne fra log filerne,jeg kan ikke se hvor jeg kan finde den faktiske dec backlash kompensentation?
Kalibreringen:
Guiding:
Hele teksten fra guide session, section heading:
Kode: Vælg alt
Guiding Begins at 2018-03-30 21:47:50
Dither = both axes, Dither scale = 1.000, Image noise reduction = none, Guide-frame time lapse = 0, Server enabled
Pixel scale = 3.87 arc-sec/px, Binning = 1, Focal length = 200 mm
Search region = 15 px, Star mass tolerance = 50.0%
Equipment Profile = ZWO120MC / 200mm
Camera = ZWO ASI120MC, gain = 95, full size = 1280 x 960, no dark, no defect map, pixel size = 3.8 um
Exposure = 2000 ms
Mount = EQMOD HEQ5/6,  connected, guiding enabled, xAngle = 162.4, xRate = 0.676, yAngle = 72.4, yRate = 1.863, parity = +/-,
X guide algorithm = Hysteresis, Hysteresis = 0.100, Aggression = 0.600, Minimum move = 0.120
Y guide algorithm = Resist Switch, Minimum move = 0.120 Aggression = 70% FastSwitch = enabled
Backlash comp = disabled, pulse = 0 ms
Calibration step = phdlab_placeholder, Max RA duration = 3000, Max DEC duration = 3000, DEC guide mode = Auto
RA Guide Speed = 7.5 a-s/s, Dec Guide Speed = 7.5 a-s/s, Cal Dec = 14.1, Last Cal Issue = None, Timestamp = 30-03-2018 21:24:14
Dec = 69.0 deg, Hour angle = -0.90 hr, Pier side = West, Rotator pos = N/A
Lock position = 114.245, 559.627, Star position = 114.245, 559.627, HFD = 3.71 px
De to log filer fra i går aftes ligger her:
http://b-rasmussen.dk/astro/2018/0330/P ... 211841.txt
http://b-rasmussen.dk/astro/2018/0330/P ... 213841.txt
Indlæg af Rudi » 31 mar 2018, 10:29
Hvad pokker, jeg ser nu at der står Backlash comp = disabled, pulse = 0 ms i log filen!!!
Jeg er 100% sikker på at jeg enablede det da PHD2 blev startet op, hmmmm..... måske skulle jeg checke om der er en ny version af PHD2 tilgængeilg, jeg har 2.6.2
Indlæg af John » 31 mar 2018, 11:24
rudi skrev:
31 mar 2018, 10:29
Og du fik også sat en værdi ind?
Indlæg af Rudi » 31 mar 2018, 11:25
Nej, den stod til 0. Regner PHD ikke det ud automatisk under klaibreringen?
Indlæg af John » 31 mar 2018, 11:28
Nej den sætter ikke selv værdien ind. Kør guideassistent og sæt den værdi ind som den finder frem til. Sådan har jeg forstået det og også gjort.
Indlæg af Rudi » 31 mar 2018, 11:36
Ahhh - men nu guider den jo så flot ;)
Venter og ser om det bliver et problem igen.
Jeg kan ikke komme i tanke om noget som helst der er anderledes end sidst, der er ikke ændret i ballancen i systemet, dog bemærkede jeg i går aftes, at dec koblingen sad temmelig stram, så den har siddet løsere i går aftes - kan det være det der drillede sidst, altså en for stram dec kobling?
Indlæg af John » 31 mar 2018, 11:44
Måske har du ændret lidt på balancen eller kørt med længere exponeringer. Husk telescopet skal være toptungt, det er vigtigt.
Indlæg af John » 31 mar 2018, 11:48
Du har ikke ændret på balancen læser jeg - sorry :(
Indlæg af Rudi » 31 mar 2018, 11:49
Ja, teleskopet er med vilje "toptungt", det har det altid været, ingen ændringer der.
Jeg kørte ingen guide assistant i går, men 23/2 gjorde jeg det sidst, og det ser ud til at der ikke er nævneværdig backlash på deklinations snekken:
Kode: Vælg alt
19:51:26.924 00.000 1480 BLT backlash clearing move of -0.10 px was not large enough
19:51:26.924 00.000 1480 Enqueuing Calibration Move request for direction 0
19:51:26.924 00.000 1480 BLT: Clearing North backlash, step 2 (up to limit of 100), LastDecDelta = -0.10 px
19:51:26.924 00.000 4516 Worker thread wakes up
19:51:26.924 00.000 4516 worker thread servicing REQUEST_MOVE scope dir 0 (0.00, 0.00)
19:51:26.924 00.000 4516 Handling move in thread for scope dir=0
19:51:26.924 00.000 4516 calibration move
19:51:29.908 00.000 1480 CameraToMount -- cameraX=548.09 cameraY=530.37 hyp=762.69 cameraTheta=0.77 mountX=197.87 mountY=760.31, mountTheta=1.32
19:51:29.908 00.000 1480 BLT backlash clearing move of 1.52 px was not large enough
19:51:29.908 00.000 1480 Enqueuing Calibration Move request for direction 0
19:51:29.908 00.000 1480 BLT: Clearing North backlash, step 3 (up to limit of 100), LastDecDelta = 1.52 px
19:51:29.908 00.000 4516 Worker thread wakes up
Så lige nu tror jeg blot, at dec koblingen har været spændt for hårdt, den aften det drillede.
