Asteroiden 2018 CB passerer Jorden i aften
Indlæg af Rudi » 09 feb 2018, 20:42
Hvis nogen skulle være så heldige at have klart vejr i aften kan denne måske ses (jeg kan ikke finde banedata, så ved ikke hvor den kan ses)
https://www.jpl.nasa.gov/news/news.php?feature=7055
https://jyllands-posten.dk/nyviden/ECE1 ... den-i-nat/
Re: Asteroiden 2018 CB passerer Jorden i aften
Indlæg af Lindhard » 09 feb 2018, 21:05
Her er lidt
https://astronomynow.com/2018/02/08/see ... -february/
At 20:10 UT (8:10pm GMT), 2018 CB passes 1⅔ degrees southeast of open cluster Messier 34 when the apparent motion of the asteroid against the background stars of Perseus has increased to almost 15 degrees/hour, or the apparent width of a full Moon every two minutes!
Shortly before 8:35pm GMT finds 2018 CB crossing the constellation border into Triangulum where the asteroid passes ⅓ degree northwest of magnitude +3 binary star beta (β) Trianguli at 20:45 UT (8:45pm GMT). If the magnitude predictions hold true, this is another opportunity to see a conspicuous star and 2018 CB in the same field of view of 8-inch telescopes and larger at a magnification around 100x.
Finally, 2018 CB passes 1.9 degrees southeast of magnitude +5.7 Local Group galaxy Messier 33 at 9:12pm GMT (21:12 UT). By this time the asteroid’s motion against the background stars of Triangulum has increased to a whopping 20 degrees/hour, a rate equivalent to the width of a full Moon every 1½ minutes.
Indlæg af Rudi » 09 feb 2018, 21:12
Tak Lars👍
Så står den jo godt. Sikke en hurtigløber!
Det er desværre totalt overskyet her.
Indlæg af Lindhard » 09 feb 2018, 21:37
Desværre også helt lukket her
Indlæg af KimLang » 09 feb 2018, 22:34
Hej Rudi og andre interesserede.
Du kan lave din egen efemeride for netop dit observatorium ved brug af JPL HORIZONS siden: https://ssd.jpl.nasa.gov/horizons.cgi#results
Ved ikke lige hvordan jeg kan indsætte et screen shot her. Men siden er forholdsvis let at bruge og du kan indtaste "2018 CB" som objekt og din geografiske position.
Sæt også et dato interval og klik "Generate Efemeris".
Mvh. Kim
