AstroArt 7
AstroArt 7
Indlæg af Rudi » 03 okt 2018, 21:00
Re: AstroArt 7
Indlæg af Rudi » 03 okt 2018, 21:03
Re: AstroArt 7
Indlæg af Jens_Jacobsen » 03 okt 2018, 21:08
Ja, og upgrade er free hvis version 6 er købt efter 1/9 2017..
Har lige skrevet til dem.
Re: AstroArt 7
Indlæg af Rudi » 03 okt 2018, 21:10
Det ser ud til at være en stor upgrade.
Skal lige teste demoen.
Re: AstroArt 7
Indlæg af Mogens Zachariasen » 04 okt 2018, 16:33
Ja, der er virkelig mange nye funtione og egenskaber i AA7:
32 and 64 bit
New 64 bit version for image processing of multi-megapixel images. More information
Proprocessing
New features and options for preprocessing.
Sequencer
Easy creation of sequences for camera control.
Planning
Script and star atlas functions to plan your observations.
Gradient removal
User defined control points and creation of syntetic flat field.
Comet processing
Six filters to study comet morphology.
Multiscale highpass
With realtime preview to process planetary and moon images.
-------------- Astroart 7.0 minor new features --------------
* Profiles can be changed in realtime.
* Blink windows save animated GIFs. Den kunne bl.a. jeg godt bruge.
* Blink windows with zoom and panning.
* Bigger preview for image and header in the Open Dialog.
* Compress stars with adaptive option.
* Crop as macro command.
* Automatic coregister for images from different sources.
* Improved autoalignment for trichromy.
* Immediate plate solve without dialog window.
* Palettes can be applied to color images.
* Smart file selection for sequences in Apply Macro and Preprocessing.
* Interpolation for photometry plots.
* Copy to spreadsheets for photometry plots.
* Telescope with calculated altazimuth coordinates.
* Telescope commands for tracking on and off.
* Script new functions for camera and telescope control.
* Script template from sequencer.
* Script template from file list.
* Connection with Aladin web site.
* Star atlas supports the GAIA DR2 catalog.
* Star atlas shows CCD frame for calibrated images.
* Optimize JPEG with comparison to original image.
* Selection of images is easier thanks to a colored frame.
* Optimized 2/3 visualization zoom (66%).
* Option for automatic zoom when opening images.
* Rectangle selection with preview (CTRL+R).
* Rectangle and line selections can be moved in realtime (CTRL+arrows/mouse).
* Improved Configuration, with aperture photometry preview and more.
* Visualization cursors can be moved slowly clicking the right mouse button.
* Numeric fields can be changed quickly with CTRL+mouse wheel.
* Option to remember the last used folder.
* Option for big fonts in status bars.
* Option for desktop brightness.
* Several minor bug fixes.
I forvejen er Astroart et fantastisk progam, så alt det her gør det bare endnu bedre.
Og det er stadig til en god pris.
Re: AstroArt 7
Indlæg af Rudi » 04 okt 2018, 18:34
Jeg har lige installeret demoen, det ser meget lovende ud. Men det kommer til at tage lidt tid, at komme ud i alle kroge af de nye features og forbedringer.
Re: AstroArt 7
Indlæg af Jens_Jacobsen » 06 okt 2018, 09:58
Har fået en gratis update da min var købt efter 1/9 17.
Fin service!
Re: AstroArt 7
Indlæg af Rudi » 06 okt 2018, 10:13
Gik installationen godt?
Jeg har også lige downloaded den fulde version.
Bemærk, der er en opdateret pdf manual med!!!
Jeg glæder mig til at teste den. Iflg vejrudsigten, ser det ud til at der kommer et par muligheder i løbet af ugen n
Re: AstroArt 7
Indlæg af Rudi » 06 okt 2018, 14:00
Så fik jeg også installeret AA7. Installationen drillede lidt, men det viste sig, at der manglede eet ciffer i mit serie no :oops:
Allerede efter et kort kik, ser denne nye version meget lovende ud.
Jeg stackede mine data for Elephant Trunk Nebula, og det virker som om resultatet er bedre end i version 6. Jeg skal lige høre Fabio om der er sket ændringer i algoritmerne.
En anden lækker feature, er at når man åbner Star Atlas, så vises FOV fra det billede van har valgt (hvis det er platesolvet).
Det er meget nyttigt, hvis man skal identificere objekter i billedet.
(Billedet er mit Elephant Trunk Nebula billede, fuldstændig ubehandlet, blot stacket i AA7 - og platesolved)
Re: AstroArt 7
Indlæg af Rudi » 06 okt 2018, 14:22
En anden rigtig nyttig feature, er en live JPEG compression.
Inden man gemmer som JPEG, kan man stille på kompressionen og med det samme se, hvordan billedet kommer til at se ud, samt hvor mange bytes det fylder.
Genialt!
[youtube][/youtube]
Re: AstroArt 7
Indlæg af Rudi » 19 okt 2018, 08:17
Morten gjorde mig forleden opmærksom på, at en de-bayered fits fil, som han skulle se på, var nedskaleret med en faktor 2!!!
Det fik mig til at tænke og se nærmere på AstroArt indstillingerne.
Det viser sig, at i AstroArt 7, der er binning pr. default sat til 2x2 !!!???
Jeg ved ikke om det bare er på min installation, eller om det sker for alle AstroArt 7.
Men hvis du bruger AstroArt 7 med DSLR RAW fits filer, så dobbelt-check lige dette.
Re: AstroArt 7
Indlæg af Jens_Jacobsen » 20 okt 2018, 20:17
Hvad er pixelcount med 2x2 slået til og fra?
Normalt er farvebilledet jo netop binnet 2x2, da det er din Bayer matrix.
Har iøvrigt lige skrevet et indlæg på astroart forum angående tidsserie fotometri.
Re: AstroArt 7
Indlæg af Rudi » 21 okt 2018, 08:01
Jeg har talt med Fabio, 1x1 er default efter installation, så det må være mig selv, der er kommet til at sætte til 2x2, hmmm - det forstår jeg ikke. Må lige prøve at installere en gang til.
Jens, det er jo rigtig at Bayer masken er 2x2, men indstillingen her er på RGB billedet.
JesperLF
Re: AstroArt 7
Indlæg af JesperLF » 21 okt 2018, 10:23
Jeg installerede AstroArt 7 fredag aften, det er første gang nogensinde jeg installerer AstroArt så der var ingen gamle versioner eller gamle konfigurationer på PC'en. Den omtalte dialogbox stod til "Binning 2x2".
- jesper
Re: AstroArt 7
Indlæg af Rudi » 21 okt 2018, 12:26
Tak for info Jesper. Jeg giver lige Fabio besked.
Jeg prøvede at geninstallere. Men den forblev på 1x1. Glemte ag checke om AA7 ryder op i registry.
