DSS 4.2.0
#1 DSS 4.2.0
Indlæg af Rudi » 12 jul 2019, 09:33
Jeg så lige på vores svenske søster forum (LINK) , at Deep Sky Stacker nu er klar i version 4.2.0.
Link til DeepSkyStacker 4.2.0
På deres gitHub side fremhæver de følgende:
  1. Support for images from cameras that use the Fujitsu X-Trans sensor (new in 4.2.0 Beta 2).
    The image is converted to a 3 colour RGB image and interpolated using Frank Markesteijn's algorithm using LibRaw::Process().
    Please note that the interpolation is quite slow (about 40 seconds per image on my Core i7 laptop).
    The image is then imported as if it were a Foveon colour image.
  2. BSD 3 clause license file added.
  3. A fix was made to correct crashes caused by a thread-unsafe assignment in the smart pointer code.
  4. The "Stop" button on the progress dialogs should now actually work!
  5. The space key can now be used to check/uncheck images in the picture list.
  6. The user's default browser will be used instead of IE to open URLs.
  7. Miscellaneous code cleanups and performance improvements including Median-Kappa-Sigma processing.
#2 Re: DSS 4.2.0
Indlæg af Lars Malmgren » 12 jul 2019, 13:29
12 jul 2019, 09:33
DET var en god nyhed !!!
(siger en Fujifilm kamera-ejer :D )
Dog synd, at konverteringen af de 55+ Mb frames er så langsom...
Brugere der viser dette forum: Ingen og 14 gæster
