hvad skal de bruges til ?
nik-nik
Tilmeldt: 23 jan 2018, 07:09
Indlæg af nik-nik » 03 sep 2019, 06:57
kom til at købe et par ældre CCTV (overvågningskameraer) af ukendt herkomst, de ligner mest en lidt opdateret version (klon) af det gamle Monacor kamera - hvis nogen skulle kende det
elektronisk blænde og lukker
optikken er en zoom ..2.8-12mm/1.4
lukkeren er opgivet fra 1/50-1/100000 sek
chippen er Sonys Super-Had -1/3"
opløsningen...sd TV..eller 720 linjer
- lurer lidt på om der kunne laves et brugbart planet kamera ud af et af dem, eller om de måske kan få bedre anvendelse ?
Re: hvad skal de bruges til ?
Indlæg af outlook » 03 sep 2019, 07:48
Tja, her er de fleste af forskellene på et astro og overvågningskamera:
"Let's take a second to review how an security CCTV camera works. Essentially, the following happens.
-Start the exposure
-Gather photons for a set period of time
-stop the exposure
-convert the CCD signals to digital format, this adds a bit of uncertainty - or noise, to each reading
-modulate the digital signal to analog CCTV format, possibly altering the lines/resolution of the resulting picture
-Repeat this, 25 times a second
Now with astro-cams, there are far fewer operations - typically the cycle runs once every few, to few hundred, seconds, so there's less noise added from the fewer digital conversions.. Astro cams also to not have the lossy analog modulation stage and, as the cameras are cooled, add far less noise at each stage as well. If you stick your finger on the chips of a security camera (I have some of the little board-cams), you've be aware that they do run quite hot.
So, in short, security cameras are designed to give real-time video at high frame rates. The human watchers of their screens aren't looking for static objects like stars, they're looking for moving objects like criminals - so they aren't too concerned with the level of video noise.
It is possible to capture the video and integrate / stack it, but the quality of the picture you get, compared with the quality from an equally long astro-cam, is much much worse. These cameras are designed to do a different job. And although they appear to have a lot of the same function as astro-cams, they are not intended to produce the same quality from static scenes and so aren't a great solution to seeing dim objects through a telescope."
Man kan godt bruge dem til EAA, altså videoastronomi i forbindelse med DSOer sammen med stacking software, men disse analoge tingester er nu overhalet af de lysfølsomme digitale cmos kameraer med høj opløsning sammen med netop stacking software.
Indlæg af Rudi » 03 sep 2019, 08:25
Du kunne måske bruge det som all-sky kamera og tilslutte dig meteornetværket?
http://www.stjerneskud.info/omdette.html
nik-nik
Indlæg af nik-nik » 04 sep 2019, 06:22
Meteor netværket kunne være en mulighed, men for at få et anstændigt felt skal det 8-10 m op
- begrænsningerne kender jeg skam....men alt i alt er bare at sende det i en AD converter og smide det i en USB port....det er jo lav opløsning, så selv et stort antal frames vil ikke tage lang tid at stacke....
nik-nik
Indlæg af nik-nik » 08 okt 2019, 20:29
fifler lidt med skidtet ....der er nogle mærkelige issues....de er begge med automatik, men blænden åbner ikke fuldt...så det eneste jeg har set med std optikken er...sort - slår man automatikken fra lukker blænden helt
Men med en anden optik er lukkertiden fast på 1/50 sek og det giver da lidt ....opløsningen er ikke noget at råbe hurra for
